Hi , looking at buying a new MiG been a while since i owned one let alone ones like there pumping out of the factories today.
So the one I'm looking at is the HITBOX MIG Welder IGBT Inverter ARC MMA Lift TIG Aluminium 6 in 1 Welding Machine 250amps 240v (yep a mouth full)
Just wondering this machine says as you increase the amperage the wire speed changes to suit , quite a few on the Web say they do the same.
Has this been a problem for anyone I'd imagine you would have to tweak your welding technique to how the machine wants you to weld , I'm concerned welding thinner material at low amps it
will be trying to punch the wire into work or not fast enough same goes for thicker and different materials
Has anyone had one of these " I'll choose the wire speed and amp for you machines " and if the pre programming works for them
thanks for any intel
