Nigel B
AC Idiot & DC Owner (& Idiot)
Need something Single phase big chunky high Duty Cycle and that will be ultra Reliable
Down to 2 x choices :
http://www.oxfordwelders.co.uk/singlephasemig.html
S-MIG 270-1 + S-MIG 2x2 2 roll feeder + 5M intercon - light to medium fabrication, maintenance work, medium agricultural work
RRP £1090+VAT
Supply Voltage 230V
Welding Range (amps) 30-270
Duty cycle -60% @ 190 amps
Duty cycle -45% @ 220 amps
Voltage Steps 16
Fuse rating slow blow 20/32A
Weight approx 80kg
Wire Feed S-MIG 2x2
Mig wire range 0.6-1.2mm
Inductance Settings 1
Torch trigger latching Standard
Work lead (earth) 3M
Mains input lead 3M rubber
Intercon lead length 5M Standard
Standard features; Very rugged & compact wire feed unit, synergic control means very easy to set & use, Oxford Cap+ technology ensures a very smooth stable arc with the best arc starting, electronic motor brake & burn back fitted, torch trigger latching fitted, very energy efficient design.
Options;Digital meter kit, Spool cover, Upgrade to 4x4 wire feed, Upgrade to 10M, 15M or 20M intercon
or
http://www.migtigarc.co.uk/MIG_Welder/mig_welder.html
Thermal Arc Fabricator 250 Compact Mig Welder
The Fabricator 250 Compact is a multi-voltage, single phase high output and high duty cycle DC Power Source. This unit is the ideal choice for single phase use for light and medium fabrication and heavier maintenance applications. The 250 provides excellent arc characteristics with Gas Metal Arc Welding (GMAW) and Flux Cored Arc Welding (FCAW) with or without gas. This model has 16 step voltage selection, overload protection, trigger latching facility, weld setting selection chart and adjustable burnback control.
Anything else I should add to the "Consider list" similar or better to either of the above, and thoughts on the 2 x above ?
Ta
Nige
RRP £1090+VAT
Supply Voltage 230V
Voltage Steps 16
Weight approx 80kg
Wire Feed S-MIG 2x2
or
Ta
Nige
