W.olly
- Radcliffe, Manchester
Now i didnt learn for the second time on lending tools, but i did, i let my neighbour lend my Clarke 151TE mig for a chap to do some welding, well a lot of welding on a van, it was fine when it went but on return and after a full 5kg of wire, and 3 10l bottles of co2
it was returned, i could of built a new van with that lot, but it did need a lot doing as the reason i didnt take it on.
Anyway, i turned it on to do some needed work, it didnt feed the wire, all coiled up, ok i cut back cleaned the feed wheel as it was covered in scrapings from the wire, obviousley he kept jamming it, i got it going again but to find the gas continued to flow through the torch
, i stripped the torch and checked it, all seemed ok si i put it back together, it flowed on tinuse for a minute but than after a quick tap it was ok again. by this time i was down the road after him to kick his ass. Oh well he wasnt in
I went back and had a brew then went back out, now i got it running but it welds like pigeon poo, no matter what setting, why is this, i had the feed speed on 6.5, 2 high, that normaly does a great weld on 3 mm plate, even 4mm as befor eit went out i just welded a table together from scaff pole.
Has he knackered alltogether?
please before he comes home
it was returned, i could of built a new van with that lot, but it did need a lot doing as the reason i didnt take it on.Anyway, i turned it on to do some needed work, it didnt feed the wire, all coiled up, ok i cut back cleaned the feed wheel as it was covered in scrapings from the wire, obviousley he kept jamming it, i got it going again but to find the gas continued to flow through the torch
