Hi All
I am knew to Tig welding and would like some tips to improve tig welding.
1. What is the best movement to move the tig gun when you pushing welding puddle?
Should you zig zag the tig gun or make small circles with the tig gun?
2. As a beginner is it better to tig weld with 2.4mm filler wire?
3. If you welding 10mm mild steel together, what you should tig welding machine setting be?
Should it be on 90, 115 or 130?
4. How do you tig weld so that you have puddles that overlap?
5. What should your gas setting be? My gas setting is on 15? Should it be higher?
Regards James
Regards James
