Guys, i need some MIG welding help please..
I'm new to welding and I have come across a problem today, which i havent had before..i dont know if its an equipment/setup fault or something i am doing wrong.
I am just trying to tack a 1mm thick stainless tube to a 12mm thick mild steel flange. (an exhaust pipe to a flange)
Its a bit arkward to explain but when a try to make the tack in the join, it refuses to arc..the wire feeds out, touches the metal, gets stuck and then i just get a buzzing sound.
However, If i try to place a tack/or run a bead on either of the metal peices seperately it welds fine.
The problem is only there when i try to put a tack in the join of these two metals, it refuses to weld at all.
I havent had this problem before when doing this exact same task on the same setup, so i dont understand why this is happening now.
I am using a Clarke 150T with 0.8mm stainless wire, and argoshield light gas.
