Music Guy123
New Member
- Cambridgeshire, United Kingdom
Hi,
Currently don't have much money to spend on a welder, so need advice on a cheap welder (ideally I'd like to avoid the chinese things that probably aren't going to make it to the otherside of Christmas!).
I need a welder that will be able to do 2-6mm (more likely 3 or 5mm steel). Most of the stuff will be plate, box or angle. Apart from that, it's working on cars (not panels though) and for anything that can't be done by it I will need to be able to tack the metal in place by the welder so I can get it to the farm workshop and get it done properly.
I was looking on ebay, there seem to be loads of Oxford oil cooled arc welders, are these any good? I'm told they are reliable but welding wise, will they be any good? Any tips for buying one second hand?
I currently only have single phase, but the barn I'm based in used to be part of a farm area so I don't think 3 phase is too far away but would rather not, amp wise, I think the electrics might be uprated for 30 amps or so but I need to check, so if I could run it at 13 amps, that would be preferable!
Anyway, look forward to hearing your advice, all the best
. So my solution is to get a cheap welder now that I can work with for a bit and do the main stuff I need to get done now and then when I have the spare money I still plan on getting a decent MIG welder (probably a portamig).
