Benthosboy
One of life's pillocks!
...for a project. It could be a "how long is a piece of string" question, but here goes.
I recently acquired, originally from a 4 wheel drive of some kind, a nudge/bull/roo/bumper bar (delete as required, depending on location
) that I intend to fit on my Toyota camper, after some modifications. I've cut off the horizontal "wing" parts that wrap around the headlights as I only want the central "A" bar for mounting some spotlights on.
Having cut the wing things off, made of 35mm s/s tube, I'm now left with six 35+mm holes in the A bar, made of 60mm s/s tube, 1.5mm wall. I assumed that the 35mm tubes were simply radiused and butt-welded to the A bar, but it turns out they fit into pre-drilled holes before welding.
Can anyone give me a rough idea of what it would cost to have the holes filled? If it's an expensive job, I'm prepared to bin it. TBH, I scrounged the bar from a scrappy so it doesn't stand me anything, other than the time it took to slit the wing things off, about 15 mins.
Thanks in advance.
Martyn.
) that I intend to fit on my Toyota camper, after some modifications. I've cut off the horizontal "wing" parts that wrap around the headlights as I only want the central "A" bar for mounting some spotlights on. Having cut the wing things off, made of 35mm s/s tube, I'm now left with six 35+mm holes in the A bar, made of 60mm s/s tube, 1.5mm wall. I assumed that the 35mm tubes were simply radiused and butt-welded to the A bar, but it turns out they fit into pre-drilled holes before welding.
Thanks in advance.
Martyn.
replies. I'll rephrase the original question
, if it will help.
. it's essentially a length of 60mm diameter x 1.5mm wall s/s tube that has 6 x 35mm diameter holes drilled in it. Can anyone give me a rough idea of how much it might cost to have the holes filled? I realise that this project carries enormous risks for all humanity, so if it's overly expensive, I'm inclined to put it back into the can of worms it came out of
