How did you drill 63mm in a minibeast? Did the broach not foul on the magnetic Base?I have the JEI mini beast 110v. Good bit of kit. Stated max hole is 30mm diameter but I have gone up to 63mm dia no bother through thicknesses up to 1" solid and regularly did 35mm dia through 50x50x5mm box no problems.
Good cutting fluid and letting the cutter do its job is key to preserving the cutting faces on the cutters.
The mini beast is around £340 I think new, but it's a more substantial bit of kit than evolutions products that are more serious diy than pro use.
by my reckoning that's about 200 holes, 12mm dia in 12mm thick. Last week I drilled about 30 holes 12mm dia in the top flanges of some rsj's with a pistol drill and it took about 4 hours and I had raw hands from pushing so hard!! I agree too that positioning a mag drill would take a while. I think a pillar drill or drill press is the answer as the pieces are only 6" wide and could be positioned quickly and easily. Pick a cheap one up second hand and it'll pay for itself on this job alone, and you've got it for next time, result!Think I would be inclined to get a big slow pistol drill. It wont take that long once you are in the rhythm and probably faster than repositioning a mag drill for every hole accurately.
not at all...seceret is to centre dot the hole and the pin inside the broach cutters just fall into the hole then magnet on and go....secondsby my reckoning that's about 200 holes, 12mm dia in 12mm thick. Last week I drilled about 30 holes 12mm dia in the top flanges of some rsj's with a pistol drill and it took about 4 hours and I had raw hands from pushing so hard!! I agree too that positioning a mag drill would take a while. I think a pillar drill or drill press is the answer as the pieces are only 6" wide and could be positioned quickly and easily. Pick a cheap one up second hand and it'll pay for itself on this job alone, and you've got it for next time, result!
I didn't realise mag drills had an arbor, makes sense on a big cutter but would a bit as small as 12 mm have one? I thought mag drills were were big heavy things designed for drilling rsjs and the like. I've thought about getting one as I'm a builder and have to bolt 4x2 timber to the top flange of rsjs every now and then and like I said using a pistol drill is a total pain and hiring is relatively expensive if you get one six times a year. Do they have an ordinary chuck for hss drill bits or use special cutters?not at all...seceret is to centre dot the hole and the pin inside the broach cutters just fall into the hole then magnet on and go....seconds![]()
