cheapracer
New Member
Hi Guys and thanks for taking a peek!
I am a self taught welder over 30 years, excellent ARC, fair to middling MIG.
I have a 250 MIG and have a nagging problem I can't seem to resolve - I can't get a flat weld, always I have a hill in the middle (for want of a better word) and I mean a big ugly hill on each run.
I have tried every setting combination from min/max volts and min/max wire etc. The machine uses 0.8mm wire and has a switch for 0.8 and 1.0 and I have tried every combination and I'm talking over a period of months.
I generally weld mild steel around 2.0mm thick at many different intersecting angles and verticles etc. - actually the verticles look like the others should look like.
It's like it's feeding too much wire all the time but of course I slow that down and then it burns the wire off too quickly, so I turn the volts down and then it doesn't have the heat blah, blah......
I have been using a gas mix of Argon and CO2 because I was told it produced a nicer looking weld which I believe it does even at twice the price. I also use a low gas speed/volume simply by turning it down until it had an effect then turning it back up a little.
There is also a wire tensioner/roller inside the machine, I have played with the settings but can't seem to appreciate any difference.
Any tips would be great
Mark :-)
Mark :-)
