Hi,
Hope some of this helps others - and a question at the end.
I'm not a welder but on a whim last week I bought an old "not working" and "badly butchered" Clarke 100en mig welder with gas conversion for few quid.
Note the Clarke manuals don't show the actual circuit layout but more like a generic one.
1. Fully degreased it inside and out with paraffin.
2. E1285-4 PCB faulty (very bad previous repairs).
3. 33R wirewound resistor open circuit replaced £0.15p.
4. Thyristor TYN 408 burnt out (no longer available).
5. Replaced with equivant 400v 8A TIC116D Thyristor £0.77p.
6. Several solder bridges between tracks tidied up.
7. Two tracks replaced with wire.
8.. Torch hanging off - Remade joints and reassembled.
9. Wire feed reassembled correctly.
10. Replaced all cabinet screws with screws of the same type.
Now its working fine (welds and thermal cut out kicks in when it should) and it looks good (But I might repaint it).
(NOW! comes the hard part learning how to use it!)
So finally a few questions to those who have an older version of this welder.
? When you turn ON the power switch does your power switch light up?
? When the thermal switch kicks in, what does your switch then show?
And finally does anyone know the colour code for the Clarke paint and how to calibrate the preset potentiometer on the PCB.
Thanks in anticipation
Nick
Nick
