So some of you have seen my thread on my learning process of doing aluminum. Well this thread is about the same machine, just doing stainless 316 pipe instead.
Diameters vary from 1 to 6 inch, and wall thicknesses of 1/16 to a 1/4.
These pipes belong to a high temperature dying machine. You can check their web site, Gaston County.
So we got this machine and moved it from a much larger company to our much smaller one. We are in the process of cutting and modifying most of the piping to make it fit around all the other machines we have.
The machine runs fabric threw a keer, with water,salt,and chemicals. The "Vessel" is heated with steam and keept under pressure to be able to reach a higher temperature than the boiling point without boiling, thus changing the atmosphere inside the "vessel". This is what alows us to dye polyesters and syntetic fabrics.We usualy run at 160 celcius.
So it reaches a maximum of 53 psi and the pipes have heated water and chemicals going threw them.
My welds are done with 1/16 thoriated with traditional cup(6) and 50 amps controlled via pedal.
Filler is 316 stainless, I am cleaning all the joints with a flap wheel then acetone inside and outside the mating pipes.
Ive tried all different argon flows...from as low as 4 to 15 lph. My post flow time is at 12 seconds and Ive got it set to DCSP.
all my welds are blackish, but clean up nice with a brush... on with the pics!
ok heres a joint setup for welding. I did this one vertically...not easy to stay straight.. i ddint clean this joint up
here it is welded
here is another joint
befor cleaning
After cleaning
One of the plumbers at work is telling me its looking black like this because the stainless is "old"....i think ima get some "new" stainless pipe and try to weld a small piece if i dont get any answers as why my welds are turning black..
Thanks
here it is welded
befor cleaning
After cleaning
Thanks
