I allways use my knipex side cutters to cut my fingernailsView attachment 148942
To cut my toenails.
You can laugh, but i tried to use a set of nail clippers once and ended up needing four stitches.
In my thumb.
From the *toenail*
the only one don't cut and I trim carefully is my left hand thumb nailneeded every day for bending flex conductor over on the ends .its a pig to do if it breaks
yep leftyAre you left handed then?, I use my right thumb nail for bending cores.
I used a die grinder & a very small dremel type cutter on my big toes. I thought it was just me.Dremelloid and sanding drum for the toenails...
Dave H. (the other one)
Soak your feet in the bath before hand. Makes cutting them very easy![]()
Beat me to it.![]()
Conventional nail clippers won't touch my toe nails. I bought some side cutters from the local tool shop, told the bloke what I wanted them for and he said the local chiropodist uses them rather than the proper nail clippers.
PS - I also use a steel cat comb for my hair, plastic combs just break. I draw the line at using a Dremel to clean my teeth though.
Don't need a comb any more! Pledge & a duster maybe![]()
