Very nice to watch and clearly easier work than my Eagle surface grinder. Out of curiosity, do the wheels mount directly on the spindle or are they fitted to balanced hubs? Mine mount straight on the spindle but I have a balancing going unused. Do you plan to grind that magnetic chuck?At last I have finished fettling the old Brown and Sharpe I acquired.
I have never used a surface grinder before. I love it! Working very well - not bad for 90 years old!
I could watch it all day.
Straight on the spindle I think.Very nice to watch and clearly easier work than my Eagle surface grinder. Out of curiosity, do the wheels mount directly on the spindle or are they fitted to balanced hubs? Mine mount straight on the spindle but I have a balancing going unused. Do you plan to grind that magnetic chuck?
That's lovelyAt last I have finished fettling the old Brown and Sharpe I acquired.
Smaller wheels give a lower surface speed. Less metal removal but also less heat into the part. One old chap I talk to says always use a smaller wheel for truing the chuck.Mine is 3 phase, so I converted it from star to delta and run it from a cheap VFD.
I am careful not to exceed the wheel speed, but the VFD allows soft start and the possibility of using smaller wheels (with higher speed requirement). I am told that running a wheel at reduced speed will alter its grinding characteristics, which may be a useful in the future.
Most Eagles were likely one HP. Mine was fitted (original equipment) with a 1 1/4 HP Motor, so just a tad more oomph.
