I was just doing a bit of welding tonight, when the wire feed stopped. I could hear the motor, so thought the wire had jammed. I looked at the welder and it looked like the torch had disconnected from the body and the wire was spewing out there. On closer inspection, the torch was connected, and the section that it connects to had actually become detached from the wire feed tube. The threads had stripped where the section the torch locks into screws into the wire feed tube. This must have happened when it was made (2-3) years old i think and its been weak and finally broken.
This pic shows the broken part in situ:
This shows the stripped thread:
This pic shows the thread on the end of the wire feed tube (i've removed it from the machine at this point:
Can i buy the part in pic 1 as a replacement part? The welder is a Butters AMT 180C (since its where the torch connects, i'm hoping its common to many machines and not just this one!)
As a temporary repair, can i wrap PTFE tape around the end of the wire feed tube such that it sits tighter in what little thread is left in the broken bit? - if i use PTFE tape, will this either mess up an earth connection since the wire feed tube is earthed, or get too hot here (i've no idea if this part gets hot during use!)
Any other ideas to repair it??
Thanks
Thanks
