Wendelspanswick
I thought I would add my latest acquisition to the growing list of mills on here, it's a 1980's Chinese made Kunming Universal Mill.
I was a bit dubious about buying a Chinese made mill but I am pleasantly surprised, it has a good quality finish, minimal backlash and runs sweet as a nut.
The mill has power feed to all axis and has 8 spindle speeds and 8 feed speeds all through gearboxes so no belts to change.
The vertical head tilts and has a quill feed so it can be used as a drill press as well.
It came with a 2 axis tilting table that bolts on in place of the original table, about 40 S20x2 collets and chuck, 4 horizontal spindles, a suds pump and even has the original manual in passable English.
The design is a copy of the German made Deckel so no awards for originality.
Table is 750mm long so it makes for a compact mill but it weighs over a ton with the additional table.
The only down side is that the current chuck system has a maximum capacity of 18mm so if I want to use cutters with a larger shank size I will have to either buy some 4 Morse Taper end mill holders or buy a ER40 chuck system.
