Hi all,
I have just been given (on a 'if you can get it working and you like it, you can buy it' basis) a rather rusty old Clarke 150TE MIG welder.
A couple of things with it -
- He says that the regulator used to leak gas slightly. Does this mean a new regulator is required or can something be done to repair it? I will squirt some soapy water on it when I get it hooked up tonight and see where exactly it's leaking from.
- The wire has gone rusty. I wound it off the reel slightly and underneath it looks OK, is it worth using? (Bear in mind budget is limited and while new wire is not expensive I'd rather not buy it if I don't have to, especially when I don't know if the welder works yet). Is this likely to have sodded up the liner as well?
Also, I've just realised this should probably have gone in "welders and welding machines", sorry
Cheers
Rowan
Cheers
Rowan
