Well below are my first couple of goes with my clarke 135te using disposable argon/co2 bottles.
Starting on the RH bit with my first goes being on the top going right to left.
As you can see it took me a couple of goes to get the sizling bacon noise over snap, crackle and pop! Then it seemed to get better
However on the bottom row rh piece that was where i cranked the power up a notch only to find i'd miss read the settings switchs and gone to setting 3 instead of 2 hence all the holes.
Then the LH bit you will notice i was starting to get it to 'flow' a bit better.
However I cant seem to get the penetration of the metal. all i seem to be doing is putting weld on top of the piece
as shown here(the bits are in the same orientation as the pic above
Any pointers?
Using power setting 2 with wire speed around 6
Any pointers?
