brightspark
- yarm stockton on tees
yes most pedals are electric and operate a solenoid air valve but the one in the link above is air operated . there ok to use on suction guns in a cabinet but personaly i wouldnt use one on a pressure fed pot just use the supply shut off tap as the pot has to fill and pressurise first then empty when shut off ..the solenoid switch one would be best to use if one was fittedDon't the footpedals usually work a relay?
I still have one of the relays from the cabinet I had.
