Hi Guys, first post here after a recommendation from a Land Rover Forum.
I'm looking at buying a fairly hefty single phase mig welder with a budget of £700 max for the welder itself (ideally including torch/regulator).
It's first job will be welding a roll cage and other bits of tubework for a defender. After that I plan on using it for general fabrication ranging from a bit of bodywork up to winch trays which would be 10/12mm mild steel so it needs to be fairly versatile. I have done a bit of mig before and can use one on thick stuff but am by no means professional so one that is easy to use/set up would be a bonus.
I've only got a single phase power supply, 13amp at the moment but my electrician mate is going to install a blue plug connection into the main fusebox so that should not be a problem.
I'm currently looking at 3 different welders and wouldn't mind some advice.
The first is a Murex Tradesmig 245, its had a lot of use but all works, it just needs a new earth cable and gas pipe. It's going for about £200.
The next is a secondhand but never used Murex Tradesmig 260-1. This is going for about £600
The final one is a new Portamig 235, brand new from Weldequip for £689 inc vat.
Any advice/comments appreciated
Harry
