Hello, and welcome to the Forum!
Is your machine a Tradesmig 165?
When the wirefeed stalls, does the arc continue, and the gas valve remain open?
When the fuse blew, was it inside the machine, e.g. near the auxiliary 24v power transformer, or on the printed circuit board, or was it an external fuse or breaker supplying the whole machine?
So you can still feed wire with the inching feed button, can the machine still strike an arc at the torch tip?
Hi,many thanks for response,Answers below and will get more info today on this,really appreciate the help.
Is your machine a Tradesmig 165? Yes it is
When the wirefeed stalls, does the arc continue, and the gas valve remain open? Yes it does
So you can still feed wire with the inching feed button, can the machine still strike an arc at the torch tip? Got to check that today
