AirConTechnical.com
New Member
Can anyone advise me on these
MULTI PURPOSE
TIG WELDER
PLASMA CUTTER
ARC WELDER
I was going to buy a better welder (currently I've a Clark Stick welder). I need something that will weld thinner and thicker when required. Further I wanted to see how much Plasma cutters are. Upon checking Ebay I see that there are many combination units. Are they any good?
I need to be able to cut open 5mm thick steel casings.
Weld from 0.8mm sheets to 5mm bar to bar, steel. Most work is outside.
Any ideas..in the meantime I try and read as many old posts as possible..
Thanks
Paul
MULTI PURPOSE
TIG WELDER
PLASMA CUTTER
ARC WELDER
Thanks
Paul
