Splatterer
Hi,
Beginer question.
I know from reading threads on here that ARC can be used in layers to build up a thick weld on thick materials due to the parent metal being melted by the arc .
I also found out that MIG melts the parent metal by heat from the weld pool and therefore seems to need a single pass with a suitable sized machine due to heat dissapation on multi pass.
The question is, Is that entirely right? and,
Is it entirely due to the electrode size, ie would a MIG with 2.5mm wire then act as just like an ARC rod at 2.5mm and melt the parent metal with the arc and previous welds to form a strong bond.
Or are there more of those mysterious forces at work that seem to crop up when trying to learn welding.
Thanks.
Beginer question.
Thanks.
