I have no lathe skills and am still learning. How would I go about mounting something like this on the lathe. A bearing is pushed into it but at one side it is worn a bit so when the bearing is pressed in full it goes loose. But it starts off tight so it's only worn on in. I would need to fill the worn side with weld and then lathe it off.
The hole passing right through it is not used and maybe not exactly but its damaged too so could be way off.
I dont know if the jaws go small enough to mount them in were the bearing goes and clean the back side flat and centre the through hole.
That'll leave me a flat side to mount against and a true centre hole to go by but I've still no idea then how to mount it again to machine where the bearing sits.
It's hard to explain what I mean.
