Would 3mm mild steel be rigid/strong enough for mounting plates to hold casters which will be mounted adjacent to a steel frame?
I could add supporting webs, but the casters will essentially be bolted to the 3mm plate alongside the frame rather than directly under the frame, so I'm concerned about the plate distorting when a load is applied.
Load will probably be 275kg across 6 casters.
