Screwdriver
I need some advice regarding welding this:
It's a mates bike and I have said I'd have a go.
The plan is to weld it in situ. Just taking the cylinder head off will cost hundreds. I am planing to grind it back and clean the area thoroughly of course. Then hit it hard and fast with the TIG set to 100-150 amps (??), get some rod in as quickly as possible, then let it cool a bit, hit it again, repeat until filled.
I am assuming I couldn't fit the steel/stainless stud and weld over it?
So either drill and tap or fit a helicoil. It's not a structural item so I'm happy to have a go, it just needs to hold one of two studs. If it fails in service, the exhaust will not fall off. In any case, if it doesn't work, he's going to buy a new head for it. I have an old dead cylinder head to practice on.
Any tips?
Screwd.
Any tips?
Screwd.
