gordon stephenson
- Skelton in Cleveland U.K.
I'm hoping one of you knowledgeable electrically gifted people can point me in the right direction, I'm still going ahead with building my daughter a pig roasting rotisserie despite having my hollow box section stolen, I'v just managed to get a very nice Parvalux motor and gearbox but need help with wiring,
Inside the motor connecting box is a terminal block 1 black wire and 2 white wires with separate earthing screw to the motor body,
I connected a live to the black and neutral to one of the white wires, the motor just buzzed but would run if spun by hand in either direction, same happened when I swapped the neutral to the other motor white wire, Is my problem because there isn't a capacitor and if so from the info below what size/type will I need to get and where do I wire it to,
P.S. the revs will be further reduced using sprockets and driving chain,a little it of the old trial and error for best cooking speed, unless you can advise what revs I should be aiming for from previous experience.
all motor plate info as follows,
MOTOR>
volts 230/250
Hz 50
phase 1
amps 0.66
watts output 95
rpm 1400
rating cont TEFC
GEARBOX.
73.4 Nm
rpm 6.5
Many thanks Gordon,
MOTOR>
volts 230/250
Hz 50
phase 1
amps 0.66
watts output 95
rpm 1400
rating cont TEFC
GEARBOX.
73.4 Nm
rpm 6.5
Many thanks Gordon,
