charlysays
- UK, Wales
So I had a W202 Mercedes in for a repair the other week.
Specifically the EIS (electronic ignition barrel/ switch) was causing the car not to start and stall once started (failing microswitch in the tumbler).
I tried all sorts to fix it- tried dismantling the EIS to get to the microswitch (couldn't but have since found a video on youtube showing how to get the PCBs apart), tried soldering the ICs from the bad one into a good one but that didn't work either (one had a slightly different chip number so no play).
In the end I fitted an Immo emulator in the ECU and did the required programming changes on the ECU immo chip, fitted an ESL emulator (electronic steering lock emulator) and fitted a used barrel with two keys from another car.
Car is now fully functional but has no steering lock- the ESL has been disconnected in the open position and an emulator plugged in in its place.
My MOT tester does like to thoroughly test steering locks and nearly failed my own Merc because the steering wheel can sometimes, with force, jump the steering lock in one direction. Personally I think that this still results in immobilisation- you can't drive a car where you can only turn the steering wheel one way (with force) plus it has other forms of immobilisation as detailed below.
I found this on the MOT testing training centre
It says that it's acceptable to have no steering lock provided there are other means of immobilisation.
In the case of this Merc, it has an infrared key. Only that key and the spare will allow the car to move, let alone start.
If the key isn't accepted by the EIS, you can't turn the key. If you can't turn the key you can't even get the transmission out of Park, let alone start the engine.
So it appears the car still has a permanently installed immobiliser acting on both the engine and the transmission.
What's the best way to approach this? I don't want to show up to an MOT with this document and put him on the spot. Maybe calling in informally to chat about it long before the MOT would be the best route?
Will print it out and have a chat with him well before the MOT.
