julianf
- devon, uk
I've done a fair bit of lime plaster, gypsum plaster, concrete, stone walls... But zero block work.
Need to build a very small retaining wall. This is the job -
The posts are set in concrete, which goes down below the new concrete level, by, i think, somthing like 8". There's steel in the new concrete base, and the soil is very stable anyway (job has been as in the photo since last year, and you can see virtually nothing has fallen through!) but id like the retaining wall to bond in with the old post concrete to keep it all stable too.
The soil level on the other side is at the bottom of the lowest rung - so it's not like the fence is holding back mass really.
My plan is to do 4 courses of blocks, obviously with the joints staggered, not like the photo!
The post hole concrete will stay, so I'll build around them.
I then thought I'd chuck some steel mesh in the remaing 4" or so gap, and pour concrete in there too.
But on to my question -
Do you use sharp or soft sand for retaining wall mortar? Or a mix? Google is inconclusive.
Probably thinking a 1:3:1 mix (cement:soft:sharp) - does that sound about right?
