Fred Trevvett
- Harrogate UK
Having replaced my davinci 1.0's hotend for a chenesium one (original one got clogged and decided to take the opportunity to swap for one with replaceable nozzles), the printer now won't heat the nozzle any more than 150deg.
I've tried feeding filament through with manually typed g-code and it doesn't flow, so the temperature is obviously too low, so it can't be a problem with the thermistor.
I'm guessing the issue is I have the wrong heater cartridge? (12v 40w) I can't find the stock specs for a davinci (mine is flashed with repetier by the way). Is there any way I can change the firmware to put out more power to increase the temp??? Or is that a stupid idea? If it is the wrong cartridge, if someone could point me to the right one that would be much appreciated...
