hotponyshoes
- Somerset. Uk
So to work out how much motor power would be needed to turn a rotary table / weld positioner,
In a "worse case" the table was mounted vertically (like a lathe chuck) as a rotator with a 100kg load at 1m away from the center,
9.8nm = 1kgm so 9.8x100 = 980nm.
If the table has a 90:1 reduction then
980/90 = 10.8
So only 11nm of torque required to lift a 100kg load? Sounds low to me but then it is a 90:1 ratio..
Obviously not accounting for any drive losses or the fact that a 100kg item may well be larger than 1m but presuming the table will be used horizontally and only rotating a load rather than lifting it then the actual input torque needed will be in the region of sub a couple of nm or so?
980/90 = 10.8
