As in one in each hand ? That I must see.Could you use 2 welders in parallel to weld thicker steel with TIG or stick?
Seen him before. Such a flash bugger at the end. I have enough trouble handling one torch.
Wow. Thats how you build a football stadium in a matter of months!
I once watched an old Chinese welder in Singapore, stick welding, using a second rod to help fill big gaps, welding a steel frame to a ship deck, rusty old un-level steel etc. He was just feeding it in like filler rod. The end result was fairly tidy.As in one in each hand ? That I must see.
Known as "texas TIG" and it works very wellI once watched an old Chinese welder in Singapore, stick welding, using a second rod to help fill big gaps, welding a steel frame to a ship deck, rusty old un-level steel etc. He was just feeding it in like filler rod. The end result was fairly tidy.
I have to sit comfortably and securely, with my hand resting on something, usually the other hand.......
I was thinking 1 rod, more like the video with the giant rod(wonder how much that rod costs?) but just your normal 3.25 or 4 mm rod. Or use a stick welder to give a boost to a TIG. Maybe add some amps to a plasma cutter.As in one in each hand ? That I must see.
Thanks for the link, cool video.Attention. It is in german language.
