julianf
- devon, uk
As per the other thread, i now need to paint this -
I have a bottle of mordant solution, but the directions label has been lost.
From reading, it seems that i just apply it, and then wash off when its gone black?
Can i spray it on, or is it likely to rot my cheap and cheerful gun?
What is the best plan from there?
Should i use an etch primer too?
I have a tin of standard upol filler (the stuff in the red and black tin)
Im aware that they also make one for galvanised metal, which, i assume, has an etching agent in it, to key it.
Once ive used the mordant, is this still required, or can i smooth over with the standard filler, and use standard flexible seam filler?
...and should i do this before or after the primer? I noticed on the factory finish, the seam filler was certainly applied after the primer, but it seems odd putting body filler over primer?
