CRB
Before everyone says 'Stop, just STOP' it has not been done yet, and I am trying to stop it even starting the slippery slope to insurance and near death experiences.
It all starts with the gearing, these vans are slow, and relatively thirsty. There have been a few engine swaps, and rear axle swaps, but the easy way is a larger diameter tyre, which was an option anyway, but some people would like fancier wheels with less 'truck' tyres. Tyre choice is very limited in 14".
Our LT have 14" wheels with 5x160 bolts which are countersunk. There are no other available options, unless you want alloys at the thick end of a grand or so. The closest steel option, and only option, is ?2000? Transit which are 5x160 but, and it is a very big but, the Transit uses the centre bore to to register the wheel while the LT uses the countersunk fixing bolts.
There is a train of thought that it is fine to countersink the Transit wheels. That train may have been stopped, but a workaround has been mentioned, that using plain bolts instead of countersunk would work. This would mean the wheel is held with the five bolts with each working as a register. Not clever in my opinion, and others too. Far too much room for movement.
Now, eventually, to my question. Pressing the Transit wheels' mounting holes has also been 'run up the flagpole'. Now at the minute, this seems a possible solution, for those wanting a solution. I have had a look for how many tonnes a press would need to be to complete this operation, but with no luck.
Each hole is 15dia with a ?82* countersink. I have no firm information on the Transit, even if there is enough material to do this.
Any wise words would be gratefully received.
