SirDick Diodenob esquire
I have booked the car in for mot early August . The car ignition switch randomly switches on the starter motor when driving, this caused the starter motor to burn out after a 15 minutes journey during which I did not realise the starter was engaged until I stopped the car when the starter was already on fire, white smoke billowing out, I was happy that the car did not completely catch fire, it was a lot of smoke. I fitted a second hand starter and bypassed the clutch pedal starter switch to manually switch off current to the solenoid but its an on/off toggle switch so I expect that will not do for the mot ? I also have a push button type switch in a box, its an industrial type AEG wafer switch mounted on a din rail which I will screw to the dashboard. I want to wire this to bypass the start position 3 on the ignition switch, it looks clumsy but its not blocking the dashboard view is within easy reach, I cannot get a replacement ignition switch in time, will this arrangement be likely to pass the mot ?
