Don't know, but sort of recall someone using CV joint greese on their bandsaw gear box I guess it is less likely to escape.Where could i get this or equivalent for my bandsaw gearbox in smallish quantity's?
I can get the 600w oil in 20 liters which is the correct oil for worm drive units and is also yellow metal friendly, I just wondered if anyone knew of any available in smaller quantity's
-compressor.jpg)
-compressor.jpg)
was trying to find smething simlar a while ago and failed.
mobil glygoil 460
This any good?
Call 01623 645 645 | Fax 01623 510 287 | Email sales@hall-fast.com | Send an enquiry
Search
- Account login
- Register for an account
- Your Basket
- 0 items, £0.00
- Checkout
Home >> Consumables >> Oils & Lubricants >> Lube Oils >> Industrial Gear Oil 460
Description:
Industrial Gear Oil 460 is manufactured from high quality solvent refined base stocks and extreme pressure additives.
Application:
Industrial Gear Oil 460 has been specially designed for the lubrication of enclosed gears, Industrial worm, helical and various other speed reducing fixed ratio gearboxes which require EP (extreme pressure) lubricants. Use as received.
Performance Profile:
Property Method Units Inspection Data
- DIN: 51517: Part 3 (CLP)
- Excellent extreme-pressure and anti-wear properties.
- Good product stability at operating temperatures.
- Good seal compatibility.
- Good anti-corrosion properties.
- Non-staining to yellow metals.
- Excellent Gear protection.
- Not compatible with oils based on polyglycol.
Viscosity Grade - - 460
Viscosity at 40°C D 445 mm²/s 460
Viscosity at 100°C D 445 mm²/s 30.4
Flash Point D 92 °C >200
Viscosity Index D 2270 - 95
Pour Point D 97 °C -9
Specific Gravity @ 15.6°C - kg/m³ 0.907
Please note:
An extra charge for delivery may be applicable depending on the area of delivery and the size of your goods, we will confirm this on receipt of your order. Please contact us for more information.
View related products
Delivery Information
*Online orders over £39.99 (net) delivered to UK Mainland only. Excluding certain postcodes
- FREE Delivery!
FREE delivery available!*
- Expert Support
We know the products that you need!
- 24hr Reliability
We go the extra mile to be there
- Solutions!!!
We find you the product for the job!
Stay up to date with Hall-Fast offers, products and news!
© Hall-Fast Industrial Supplies Ltd 2015. All rights reserved.
Unit 5
Anglia Way Industrial Estate
Mansfield
Nottinghamshire
NG18 4LP
Speak to the experts today!
Call 01623 645 645
Fax 01623 510 287
E-mail sales@hall-fast.com
Send a web enquiry
View our latest feedback!
DeliveryWebsite Terms of Use Privacy Policy
Its there SY range that's suitable according to the website, OK some food for thoughtHave a look on www.millersoils.co.uk
I've just started getting there automotive range VERY impressed .
The link didn't copy properly, if you click on the oil it's available in 5 ltr drums.That looks like its made for the job!
I want something that is specifically speced for worm drive gearboxes.What about that purple stuff that Doubleboost put in his lathe gearbox?
Do Morris oils have anything similar ?
