david priestley
New Member
have seen this advertised in Classic Tractor, seems pretty good value to me but i'd like to know what you experts think.
MMA Inverters
click for larger image
MMA Inverter - 200 Amp
£206.00
MMA Inverter
A 200 amp MMA inverter - this is a very high quality machine.
These machines are extremely high quality whilst giving you fantastic value for money. They are individually inspected and tested before dispatch in our UK based Engineering facilities at Loughborough. They feature much higher quality components and design than is the norm and really are a cut above the rest in terms of both quality and performance.
As well as this each machine is UK PAT tested during its inspection and is labeled as such - enabling you to put this machine straight to work in your business or workshop.
Heavy duty duty cycle - 100% @ 152 amps and the continiously variable welding current control can be adjusted to give 20A - 200A from the front panel.
All of our machines carry a 24 month UK warranty.
We are sure these machines will provide you with an excellent working life as well as unbeatable performance and reliability.
Add to Cart:
hope i,ve managed to do this not very good at this copy and paste buisness yet
MMA Inverters
£206.00
MMA Inverter
Add to Cart:
