A mate has a K94 Shogun and the flexi hoses for the oil cooler are leaking. New ones are pricey so does anyone know what fittings are on them or know of any aftermarket parts?
i did this with a jet wash high pressure hose, not only did i get a longer hose it was the same price as a new replacement from the manufacturer but for a better producttake them off, take them to Pirteck and they make them up for you.
My mate did that on his Vauxhall van.
Thanks, that would be a good solution if we knew what size of fittings are used. Is the hose not hard to fit onto those fir tree fittings? I'd have thought it would just get blown off by the pressure
As Kayos says, they don’t come off. You don’t need Jubilee clips. You want to use the correct pipe & best to dip the pipe in hot water, else they are difficult to push on. The only way to get it apart is a Stanley knife & slit the tubeThanks, that would be a good solution if we knew what size of fittings are used. Is the hose not hard to fit onto those fir tree fittings? I'd have thought it would just get blown off by the pressure
no not pirtek they are double dear!take them off, take them to Pirteck and they make them up for you.
any hydralic hose place shop or mobile will carry the fitings and hoseThanks guys I've suggested again about getting some made up
Contact Think Automotive, they have likely made replacement hoses or adaptors to fit their Mocal coolers.
