Drains
Yeah, nah.
- Sefton, South Island, NZ
Rightho folks. There's a subject that had been confusing me for some years now. Mig welders have a fixed voltage (which the operator sets); the current is then infinitely variable, according to wire thickness, wire stickout, wire feed speed, shielding gas type etc etc.
The world and his dog always seems to be speccing migs on the basis of their MINIMUM current use (at least, if a bit of car bodywork is in the offing). See the pics below for an example of what a typical data plate might say:-
Now, it is my contention that the current on the data plate actually represents the MAXIMUM draw, for the voltage set, (eg 35A at 15.7 volts) not the minimum, (then again, it could be the average) and that people who buy welders on the basis of that lower amp setting are mistaken! In fact, it's the minimum voltage they should be going by. The welder will only draw current according to the way it is being used, not the way it's been designed/built. (that will still matter, but nothing like as much)
I'm more than happy to be shown to be wrong, but I really think there is an important question to be answered.
Opinions?
Edit - just to be a little clearer - the common assumption would be that the minimum amperage of the welder shown in the plate would be 35A. I say that is an incorrect assumption, and that the current could be less than that in use. So if you're looking for a welder to weld thin material, going by the current accompanying the minimum voltage on the data plate to choose a set would be a mistake.
Opinions?
