Mike Carter
New Member
- Guildford SE UK
Hi All, I was just wondering if anyone here has one of these Chinese 7x12 minilathes as above. I got one second hand and it has so far far exceded my competence so it's been a great learning device. However when I got it, although it came with many of the expected bits, lots of those turned to be for a different machine. My current problem is change gears, mine are designed for a 4 splined shaft whereas I have 12 mm shafts with a single 3mm key. Getting a set of gears to fit this machine is proving very difficult. I think the machine has been superceded and change gears weren't usually sold separately from the machine anyway. I have tracked down a set of generic minilathe gears in the States, but it's not possible to tell if they are an exact substitute unless I can compare gear diameters and thus tooth size. So if anyone has such a machine could you let me know the diameter of say the 80T and 45T gears please?
Many thanks all
Mike
PS if anyone can suggest a machine that the 4-spline gears might fit I'd appreciate the info.
Many thanks all
Mike
