could any1 tell me what the permitted weave is on 1mm or 1.2mm standered a18 wire using argon 20% co2 the job is 20mm lifting lugs general standerd 50 b grade carbon steel 2 15mm end plate fillit welded vertically up the way ive been doing it is block it out 1st pass to 8 , 10mm leg length then a split of 2 stringers up 2 the 14mm leg length but sum of the guys have been capping of in 1 which i thought was bit wide the job is usually dun downhand theres no procedure 2 cover the verts can anybody shed any lite on this thx
