caterpillar028
what wire should be used for both welding car bodies and 6mm plate (not together) the place i work in used 0.6 wire but it seemed to give a lot of truble and made the welder unsmooth to use but we are restoring a triumph spitfire which is like welding tin foil so i need the welder turn down as low as i can get it but i also have to weld box section on are lorry tail lifts
what wire would be the best for both
