peterd51
happy to be here!
Hi,
repairs to a Mondeo diesel, I've got the head off, one piston is slightly melted.
To remove the sump needs the gearbox, clutch & flywheel off...not an option!
I considered drilling/cutting a hole in the sump under no.2 piston, unbolting the big end and then pushing the piston out the top.
Pop a replacement piston in, bolt it up and weld a mild steel plate over the hole.
But the sump bottom isn't mild steel, it's some sort of alloy.
Any ideas please?
What wire, what gas, what metal to use for the plate?
I thought of bolting the plate on but the oil-pressure is around 70 PSI so that could be a bit suspect.
The only other option is to risk it with the piston as it is.
Regards
Peter
Any ideas please?
Regards
Peter
