Hi folks,
I need to buid a Steel Dog Kennel Door.
( Or rebuild one that's destroyed )
I bought some 6 and 4 mm steel rod for the material.
I am using a Century 85A Mig Welder.
Generally speaking, the rod needs to be welded at 90 degrees to each other, one lying on top of the other.
This will create a wire frame and door.
I am finding it difficult to weld the little spot between both rods.
Wirespeed 6 and heat 3 settings have worked, but I am getting a ball weld as opposed to a nice little pool between the two peices of steel.
Has someone already figured this technique out ?
Thanks
Derek from Whitby, Canada
Thanks
