My Clarke 150TE Turbo MIG welder has just stopped working.
The fan runs and the mains light in the switch comes on when you turn it on, but when you press the button on the torch there is no wire feed and no arc
. Any ideas on whats up with it or what to check. I'm fairly competent with electrics and understand the principle behind how a welder works, but I've taken the side off and it's a bit hard to trace where a fault might be.
It happened immediately after changing the roll of wire if that's significant, ie was working before and not after!
Cheers
Tim
It happened immediately after changing the roll of wire if that's significant, ie was working before and not after!Cheers
Tim
(or at least another symptom!) There's a miniture 500mA fuse on the board which has blown. I'll get another from Maplins tomorrow and see if it cures it. Fingers crossed there's no other problems which caused the fuse to blow in the first place.
