I have had a Monomig 150 from new in late 97! Italian made.
Never thought it was much good but now have time to investigate it in depth.
Welds were always inconsistant, generally blamed myself but thought there are better machines arround.
The instruction book was poor! so had to work things out myself.
This forum often points out the importance of wire feed.
I find my wire drive roller is 15 mil eccentric (shaft hole)! must have been like this since new. probably a main cause I will replace the roller.
Will replace the liner and tip.\
My requests.
The machine has 6 power settings anyone know the Currents. is the first setting 30amps. does this welder have stitching or pulsing at lower settings.
The wire feed control is super senitive. it works on 6 and power 2 but @ 6.2 is too fast. Anyone know the actual Revs roller or motorspeed against the settings. I need to check this.
Anyone got a circuit?
I note considerable discussion on the wiredrive power supply, will prbably install this.
Regards
GLH
My requests.
Regards
GLH
