nightowl226
New Member
New to welding. I hope to embark on some metal sculpture work later this year and would like some advice. The sculptures will range from "table top" size ( If you look at the "steelman sculpture" site and imagine a larger version of those) using 4mm to 6mm mild steel rod and small scraps down to 1mm sheet... to garden sculptures using up to 5mmX20mm flat steel , 10mm square section max and 2mm to 3mm sheet. Will one machine do all do you think ? probably have around £500 to spend on a single phase welder. Thanks and happy new year
