After researching the forum, I really want to get my first MIG welding machine for hobby car panel work.
I want to use Gas (small hobby tanks), and get a reasonability good quality MIG welder. I prefer to get something that will suit a wide range of work not just for car panels / exhaust work. ie. making support frames, for satellite dishes, solar panels, stuff like that.
I've narrowed it to these 2 machines available locally. (Australia) I've got the idea set in head that I need a machine that can go below 30A for 0.8mm panel steel. I do realise that there is AMP variation depending on wire diameter as well which I haven't looked to much into.
Both machines are at the $850AUD (535GBP) mark, which might be a bit expensive for a chinese machine (choice #1) but these are the only two that I've found that can go below 30AMP. Cheap machines either have a minimum of 30AMP or 40AMP+
Choice #1 is a chinese machine (Jasic Rebadged) offered by a local business ran by an actual welder. Have good references for other ppl that purchased this machine.
Choice #2 is mainstream brand. (Transmig / Cigweld)
Was thinking of going for Choice #1 since it can go down to 25AMP for 0.8 panel steel but also go up to 200AMP for the just incase I need to use thicker stuff.. Not sure if Choice #2 (Transmig) if going all the way down to 10AMP brings any advantage when working with 0.8 Panel steel ? Was mainly thinking since machine can only go up to 175AMP that might be a limiting factor if I eventually need to use it on thicker steel for mounts etc.
Choice #1
Magnum Mig200 Mig Arc DC Tig Gass/Gassless welder
Output Current Range - MIG 25 - 200AMPS
Output Voltage Range - 11-26v
Diameter wire - 0.6/0.8/0.9mm
Duty Cycle - 60% @ 160Amps & 100% @ 124Amps
Feeding speed (metres/min) - 1.5-14
Warranty - 2 Years
Website - http://magnumweldersptyltd.vpweb.com.au/Mig-Welders.html
PDF - http://magnumweldersptyltd.vpweb.com.au/upload/Flyer Magnum Mig-Arc200gg.pdf
Choice #2
Cigweld Transmig 175i (MIG/DC TIG/ARC)
Output Current Range - MIG 10-175Amps
Duty Cycle - MIG (GMAW/FCAW) : 25% @ 175A, 22.8V ( 40°C, 10mins )
Feed Rolls: 0.6/0.8mm - V groove(fitted), 1.0/1.2mm U groove; 0.8/0.9mm V knurled
Warranty - 3 Years
http://www.cigweld.com.au/product/mig-welding-equipment/transmig-175i-plant/
Appreciate any feedback for recommended machine.
Cheers in advance!
Choice #1
Warranty - 2 Years
Choice #2
Warranty - 3 Years
Cheers in advance!
