BuiltnotBought
Perfect will never be good enough
- brstiol uk
Morning All,
So I have a question or two about some stuff, but first I though id give a quick machine spec and conditions material etc.
So I have a nice shiney new (because clearly someone is on my side) Miller XPS 350, running 1.2mm wire through a 24v wirefeed in a Parweld gun. Argo shield (not light) is piped in and I am cooking 8~10mm sheet to 25~30ish mm (reasonably think and frigging hot)
It's a 350Amp machine with 30 power settings, I am running it on the 27th power setting and a wire speed of around 5 (mpm? I assume its measured in meters per min!!?)
So the first question is how do I know when the duty cycle is about maxed? And the second and slightly more critical I feel is why the hell am I getting a glass like layer of something, flux mayne?, on the top of the weld. I've seen it in small amounts before but its almost like a glassy version of MMA
Any ideas would be greatfully received.
thanks in advance
Al
thanks in advance
Al
as I even rarely use 1.2mm wire nowadays.
