I've currently got a Small Welder - A Clarke Turbo 150TE
I'm only an occasional user and I'm not great - I can weld so it's secure but never looks that pretty!
My problem with the welder at the moment is with the gas. It's currently setup to use the mini disposable bottles at about £10 a time. The Regulator which goes on top goes from 0-6, when turning the reg with a full bottle of gas it only starts to hiss when it gets to about 5.5. So I presume the reg is now knackered?
The gas has just run out again so I'm just wanting to make sure there isn't a better option if I'm about to buy a regulator and a bottle of gas? Is there a bigger bottle system I can go for?
If not can I convert it to gasless? Or just use gasless wire in it? I realise that you're supposed to get a better result with gas but as I'm not that good maybe it doesn't matter?!
Thanks in advance
P.S - just out of interest is the welder any good? Or would I be better saving up for a better one?
Thanks in advance
any way its not that bad. how much welding do you do? i wouldnt buy a bottle off ebay for health and safety reasons. ill update when level headed.
