Hi folks
I am looking to begin a new hobby welding steel ornaments. Never welded before so thinking this should be fun!
Decided probably a MIG welder would be best for an amateur. So now trying to find out what welder I will need. MIG welders give max current and the max thickness of steel plate that can be welded. But I want to weld mostly round steel rod. Does anyone know how to calculate the amperage needed to weld steel rods - "T" and "X" joins?
I worked out that a round steel rod of diameter D has an average "thickness" of D*pi/4 = 0.78*D. So if I created a plate of 6mm rods side by side, the mean "thickness" would be 4.7mm. But presumably I need much less current to weld four x 5mm square rods into an X than to butt weld two 5mm thick plates.
If someone can tell me how quickly (mm per second) they can butt weld steel plate with MIG (current and plate thickness please) I can try do some calculations (heat diffusion - Poisson equation!).
Or better still, if anyone has a proven conversion formula (plate to bar) that would be great.
Thanks!
Dominic
p.s. I know I could just go out and buy a big 160A/200A machine and do even big stuff, but for just playing around it is hard to justify £600+ if a £250 welder is all I need especially as it will get only occasional use. Hence my question.
Thanks!
Dominic
